86 evinrude 70 runs rough barely moves boat
Foreman92
I just recently bought a 86 mirrocraft sunsport off my girlfriends grandfather. It has a evinrude 70 on it. It sat for 3-4 years as he couldn't get in and out of it any longer. I've changed the fuel lines and put in a new inline filter. I drained the fuel tank and filled with rec89. Roughly 18 gallon tank. I put half bottle of seafoam in it. Replaced the plugs. It does run and gets me around very slow. It will run great with the high idle. But as soon as it's under load it falls on its face. I had it plane out once while I was out. Took close to 1-1.5 miles to do it. With one other person on board. I'm at a loss as to where to go from here. First boat I've owned so I'm still learning. Thanks for reading and any advice is much appreciated
flyingscott
Is the vro still connected? If not are you pre-mixing the fuel? Have you done a compression test? Have you done a spark test? Have you tried pumping the primer ball when that happens?
jbuote
And did you replace the water pump impeller?
Foreman92
Vro is still connected. Getting spark. Haven't done compression test yet. Did notice the other night it was running rougher then usual. Fuel filter would empty for a sec then get a splash of fuel. Until I let off then filter would fill up again. Tried the bulb and pulling cap to make sure it wasn't getting a vapor lock. Ran a very tiny bit better.
boobie
Do a cylinder drop test on it to see which cylinders aren't firing.
Dennischaves
Clean the carbs too
its very easy do one at a time because there different
oldboat1
If you added solvent to the tank, you need to change out the filter (maybe more than once, depending on what was loosened up in the tank).
Chinewalker
First thing - STOP RUNNING IT. If one of the carbs are gummed up, then that cylinder will not be getting lubricant. Basic trouble shooting - compression test, spark, fuel. Your description points word a fuel issue, as you said you had spark. With motor on muffs or in the water, you should be able to squirt a bit of mixed fuel into each carb throat from a squirt bottle and note if it picks up. That would point towards a fuel delivery issue.
Is the fuel filter arrow going right way? Not sure on your year, but my Johnson 65 needs vent cap open or will bog after 10 minutes of running WOT. At which time I say, damn I forgot to open the vent. I also had plane out problem, lost a cylinder so follow Chine's advice, get a cheap Harbor Freight compression gauge and also a spark tester while you're at it because they're cheap. When checking compression with all three plugs out you can simultaneously look for a strong 7/16" blue gap/zap spark from each coil. The one I bouth has a ground clamp but with good engine paint you may need a jumper wire to ground the tool. Just looking at the little spark plug zapping is ok but the high energy air zap is a better test.
