86 Evinrude 25hp Water Pump/Stall
Jira
Hello,<br /><br />I've got an 86 evinrude 25hp motor which "pisses" fine at idle. As soon as the motor is put into gear (even at low troll) the "pissing" spits and stops and the engine kills. I replaced the water pump and that has not helped. Suggestions?
12Footer
Re: 86 Evinrude 25hp Water Pump/Stall
Sounds like a leak in the water jacket somewhere. Do a compression test first.
