86 evenrude control box rebuild
dilbert
i have an 86 evenrude the shifter throttel control box bushings are worn out the throttel shifter works but after a few times i have to take it apart and tighten the screw so the shifter is tight and the fast idle lever works right the plastec bushings are worn out can these be rebuilt
tashasdaddy
Re: 86 evenrude control box rebuild
go here, follow prompts, click accessories, then the year, you will find a diagram of the controller, then you can get part numbers, and see if they are available. "http://www.evinrude.com/en-US/Accessories/Literature/?popup=true"
or buy a used one on ebay,
