Re: 86 bayliner capri
"They all read 125PSI" says it all. Welcome to the best boating forum on the web,bar none.<br />Do a search "Bayliner". Then do another search "force". <br />There are many opinions, many praises and put-downs.. I'll give you mine.<br />I own a Bayliner Capri. The construction is sub-par. It is a pretty boat,a 1989, that STILL gets "Nice boat" compliments at the ramp.<br />I love the lines, the ride, and the towabilty of this boat.<br />Problems I've had;<br />Engine (50HP Force)...Overheating. Turned-out to be a wasp nest in the intake.<br /><br />Lower unit driveshaft seal.<br /><br />Hub prone to spin-out. This hasn't happened to ME yet, but was the main problem with the engine before i bought it.<br /><br />fuel pump diaphram and carb kit. This was due to the boat sitting 3years. This fact probably had much to do with L/U seal too.<br />But mainly, the rubber parts turned into tar paper. Alcohol enhanced fuel was used before I bought the boat,allmost exclusively. This is death to rubber.<br /><br />Otherwise, flawless 12year old engine.<br />NOW, the bayliner. Lots of decking had to be replaced. Original fiberglass does not fully encapsulate the stringers or bulkheads.<br />Very poor layup,with foberglass "fur" everwhere below the decking. It took 30buks worth of resin to finish what Bliner started.<br /><br />Saying all that, I wouldn't trade her in for anything less the a Boston Whaler Outrage,because I just plain like the boat.<br />Again,welcome to the site. Nice to make new buds.
