86' Bayliner 1950 w/ AQ125B engine & 270 Drive Redo: Belows/Engine/UJoints/Oil/Etc.
jwocking
Hey, sorry for hijacking a thread. Wasn't my intention. Here's the appropriate repost.
I'm brand new to the forums and this is my first boat project with the exception of my john boat when I was a kid. I've been reading the forums while working on my new project and they've been a big help. I have been completely redoing my father's 1986 Bayliner with an Volvo Penta AQ 125 B engine and a 270 outdrive.
So Far I've taken apart the entire upper engine, sanded, wirebrushed, degreased, cleaned, painted, oiled, lubed, and/or replaced every part, nut, bolt, belt, filter, gasket, hose, wire, and spring. I got the head a valve job, replaced the exhaust manifold, installed an electronic ignition, put it back together, and changed the oil. Fun times. I think I'm getting close.
I've read up on and seen the diagrams concerning replacing the upper and lower bellows on the outdrive but I've run into a road block. I saw that it is possible to just remove the gear box to replace the bellows. I followed the diagram and successfully detached the gear box from the lower outdrive, but have no idea how to detach the gear box from the universal joints. Basically I can't actually pull off the bellows and replace them.
Also, the ujoiunts are kind of rusty, which could be from water in the bellows while running, but is more likely from just sitting all of those years. They seem really sturdy maybe just need to be cleaned up and greased. Trying to avoid pulling the engine and save some money if possible. I know I should also replace the seals and any instruction on that front would help as well.
Just a little history. The boat has been sitting on land since 1995. In 1999 I pulled off what was left of the tarp and got to work. I cleaned it all up, replaced the floor, had the canvas resewn, and repainted the bottom. Then I got it shrink wrapped and went to college.
This summer I started on the engine as earlier mentioned. The next thing to do, in order to hopefully crank her over is to finish replacing these bellows and reconditioning the outdrive.
I realize that there are probably quite few things that I'm missing which is why I'm looking for your input. Oh one last thing, which is probably the biggest problem I might have. I put the engine back together and forgot to put in one small gasket between the head and the water pump. Stupid rooky mistake. When I started to fill the heat exchanger, it started running out of the space of course.
I had already torqued down the cam shaft and head, and filled it with oil. I left the oil in, untorqued the head, and got the gasket in just fine. nice and snug. I refilled the heat exchanger to test it and wasn't losing anything from between water pump and the head. Here's the nightmare part. I didn't have a torque wrench handy, so I lightly tightened the head bolts. When I began pouring anit-freeze/water itno the heat exchanger, I immediatley noticed it starting to seep out between the head and the lower unit on the right side.
I freaked out of course, and tightened down the head bolts. It stopped and is holding water fine. I'm worried about antifreeze/water in the oil, cylinders etc. In the manuals it talks about retorqueing the head bolts after the engine is hot, so I wonder if maybe I got lucky, or if I have to flush the systems, or, worst case scernio: I have to pull it all apart, lower engine included and clean it all up, or even worse case scenario: I just killed my boat. Any input would be greatly appreciated.
So in summary, 1) I need to know how to separate the gear box from the ujoint to replace the bellows, 2) I need to know how much more work I made fro myself by forgetting that one gasket, 3) I would appreciate any other insight you guys have on this project, 4) Lastly, the oweners manual says to use 10W40 oil in the engine and outdrive. I discovered this after following the forums suggestion to use straight 30. Should I switch to 10W40? And what grease should I use in my grease gun for the outdrive?
I think that's it. At any rate, my apologies for the long post. Hopefully some of these questions will clear up some questions for other members. Thank you guys again for the forums. You guys are life savers.
captmello
Re: 86' Bayliner 1950 w/ AQ125B engine & 270 Drive Redo: Belows/Engine/UJoints/Oil/Et
So in summary, 1) I need to know how to separate the gear box from the ujoint to replace the bellows, 2) I need to know how much more work I made fro myself by forgetting that one gasket, 3) I would appreciate any other insight you guys have on this project, 4) Lastly, the owners manual says to use 10W40 oil in the engine and outdrive. I discovered this after following the forums suggestion to use straight 30. Should I switch to 10W40? And what grease should I use in my grease gun for the outdrive?
Welcome. Sounds to me like your almost in the water.:cool:
1. the ujoint yoke simply slides over the drive shaft. guess its rusted on. Might be able to tap the side or the ujoints to loosen it up.
2. I would torque it down and run it. Some may disagree.:rolleyes:
4. I don't think it matters which oil. change it every year, it should come out looking brand new. Any grease is better than none. You can buy "Marine grease", I saw it in the store the other day.
I would get the engine dried out asap. You can run the boat with the upper gear box off. Always have the water running to the engine and have the outdrive fully down.
Since your going through everything, I would replace the ujoints and I would pull the rear seal of the flywheel cover and see how the rear bearings look. New seal of course. If the driveshaft feels tight and doesn't make noise once its running, I wouldn't change the intermediate bearings yet. Need to pull the motor for that.
Good luck. Let us know how it goes.:)
Don S
If you can't get the gear box off, it's because of rust, and not just from sitting. You probably have water in the flywheel cover and intermediate bearings. This is NOT a good thing and really needs to be dealt with before you start the motor. If those bearings lock up and spin in the housing, it's going to get very expensive, very quickly.
Have a look at this thread.
http://forums.iboats.com/showthread.php?t=265021
jwocking
Don,
Thank you so much for getting back to me. I will surely follow the pointers. Is there any way you can let me know a list of which parts or part numbers I should get to replace if I am pulling the u-joints and pulling the engine for the intermediate bearing/flywheel drive? Thanks for the encouragement as well. I'll keep the forum up-to-date. Ttys.
jwocking
CaptMello,
Thanks for getting back to me. I have decided I am going to pull the engine and replace the intermediate bearings, seals, etc. Still trying to get the u-joints out of their sleeve. I let you guys know when I pull the engine. I will drain the engine today for sure. Thanks again. Ttys.
jwocking
:rolleyes:
Don,
The Ujoints sticking is definitely caused by the rust I just wasn't sure if they rusted due to water in the bellows while it was in operation or just from sitting on land uncovered and exposed for so long. Either way it seems a safe bet to give it a once over and replace these parts that seem crucial. I went through this entire forum and got the parts and numbers I need to replace concerning the Bellows/U-Joint job and the Flywheel job. Wondering if you minded confirming that these are the right parts for my engine and outdrive. It's a AQ125B engine with a 270 Outdrive.
Part - Part Number
  1. U-Joints - ?
  2. Gear Box Seals & O Rings - ?
  3. Gear Box Seal Ring & Metal Washer - ?
  4. Ball Bearing #70 - 11013
  5. Ball Bearing #66 - 181105
  6. Lubricating Nipple #73 - 914167
  7. Sealing Ring #71 & 79 - 958860
  8. Snap Ring #68 - 914533
  9. Lock Ring #67 - 914462
  10. Rubber Cushion #43 - 875531
    • Gasket #44 (X2) - 832565
    • Washer #45 (X2) - 940097
    • Nut # 46 (X2) - 950364
  11. Rubber ring #40 (X2) - 804190
I added the Rubber cushion to the list because mine rusted off and the rubber rings because I might as well while the engine is off. Wasn't sure if all of these parts and part numbers corresponded with my AQ125B Engine/270 Outdrive setup or just the AQ260 Engine/275 Outdrive setup mentioned in the thread. If there not the right parts/part numbers and you knew where I could get the right ones, that would be a big help. Thanks again.:D
jwocking
Hey guys,
I have yet to get the U-joints off of the drive shaft. Those splines are really rusted on there. I did pull the lower unit, and the helmut of the outdrive off today which is good news. Now I just have the U-joints and the gear box to deal with. Did'nt drain the lower unit yet but I'm suspecting I'll find that some water will be the first to leave the drive drain. Should I take apart the lower unit and inspect the lower gears to see if they are rusted? Are there any normal maintenance things I should do/replace to the lower drive/prop?
In other news I also drained the engine/pulled the head and I'm glad I did. There was a llittle bit of anti-freeze that came out of the oil drain and some sitting on top of the gasket, bottom of the head and pistons. I cleaned it all up and I am letting it all dry out. I plan on cleaning it with a little degreaser before reassembling everything. Is this a good plan? Is there anything else I should do to flush the lower engine unit? Is there any maintenace that I should do to the pistons/lower engine unit while I have it apart?
Also, I read the forums and could see the bolts on the outside of the boat that I have to remove to pull the whole engine as well as the wiring harness and other sundry items to disconnect on the inside of the boat before pulling. I was wondering if anyone had a diagram to show the inner lag bolts that I should unscrew in order to pull the engine properly. I was unclear on which 6 should be unscrewed. I saw 6 that looked like they would dislodge the entire transom shield but not really any bolts that were holding just the flywheel housing/engine into the transom shield.
Lasly, if you had a diagram for disassembling the flywheel cover, so I can replace the intermediate bearings and seals, that would be great too. If not, no worries, I'll figure it out. The manual is just a little vague on these issues. Thanks again for everything. Again, sorry about the long post.
captmello
Wouldn't hurt, you need 3 additional orings to put it back together. However, If the oil comes out clean and the prop spins freely, I would hold off. Not really any maintenence items.
The six bolts are outside behind the upper gear box. the lag bolts refer to the engine mounts in the boat. Where the engine bolts to the hull. You'll need to disconnect the fuel, wire harness, throttle cable, etc before removal as well.
Are you using the 270 manual? Search the threads for a 280 manual. It is more detailed and easier to follow.
As always, let us know how its goes.:)
PiratePast40
It's going to be allmost impossible to get to the clamping ring to remove the 6 bolts until you get the gearbox out of the way. If you can't get the u-joint yoke removed from the shaft, you might be able to remove clips from the u-joint crosses and pull the gearbox that way. If you haven't done so allready, be careful about the shims under the gearbox. Those exact shims need to be put back in.
If you're concerned about water in the outdrive, go ahead and pull the plug and drain the oil. If you've got water, you might get lucky and avoid further damage by getting oil back on the lower end gears and bearings.
jwocking
Thanks for the input guys. All good stuff. I was thinking that if I removed one of the U-joints, via removing the lock rings that, that would be the best bet. So I do need to remove the big lag bolts that secure the big white metal housing to the transom? Or will I be able to pull the engine by just removing the bolts from behind the gear box? Any word on a flywheel cover diagram?
PiratePast40
You really need to get the correct manual for your motor and outdrive - I thought you had one. The clamping ring is the aluminum ring that bolts to the flywheel with the 6 bolts. There is a rubber "donut" type gasket on either side of the transom shield. I was under the impression that you were aware of the mount and had allready ordered replacement gaskets. When you talk about the lag bolts, it sounds like you're talking about the transom shield carriage bolts. No - don't remove those bolts unless you're planning on removing the transdom shield which is unnecessary for engine removal.
You really shouldn't be doing anything else until you read and understand the manual.
jwocking
As for an update, I finally removed the ujoints. Thank you for the "removing the u-joint clips" suggestion to remove the gear box. It worked great. I am planning on pulling the engine tomorrow or the next day.
I have Both manuals and the suppliments. I read and understood them just fine. The confusion was concerning a previous forum post that stated that removing some interior lag bolts was necessary for removing the engine. I figured this was regarding a different engine.
I just wanted to be sure that the six bolts around the clamping ring, the main wiring harness, the throttle cable, the fuel hose, the water hose, the outdrive lift ground wire, and the boot clamp for the exhaust manifold were the ONLY things to be disconnected/unscrewed when removing the engine. I figured that the carriage bolts were not necessary to remove the engine. Thank you for confirming.
More updates to come. Thank you guys again for all of your help. Couldn't have got this far with out you. Hopefully this thread will help the next guy avoid some of the rookie mistakes and oversights I encountered. Ttys.
