86 ? 9.9 hp Mercury Prop hub
Wildey
Is there a hub kit available for a 1986 Mercury 9.9 hp prop ?
Mine got sort of gooey and is slipping now.
Or, is it made as an assembly and must I get a new prop ?
Or, any method to repair ?
Its a nice clean prop, other than the gooey rubber.
Thanks
flyingscott
Look up you serial # and see if the hub is available. If it is a prop shop should be able to press one for you.
Wildey
Thanks.
My searches come up empty.
No prop shop near here (that I know of)
Can you advise where to look ? specifically ? links ?
Thanks.
1988 Mercury 9.9 HP Serial # 0B336851
flyingscott
If it is available and with the price to install it, you could probably buy a new Solas for cheaper.
Wildey
That's what I was assuming, after looking at general prices and discussions posted around the web.
I could install it, no prob there, but still haven't seen one available anywhere.
Even asked a "prop shop", but they haven't replied.
I have urethane of several durometers to make one out of, and polyurethane adhesive to bond it in with. I'll make it work just fine. Sandblast the surfaces and machine it for a press fit.
Thanks
