85hp
djdave
hello i i hope somebody can help me. i have a 85hp i need to change my oil in the lower uint.i need to know what tipe of oil do i put back in. can i put car gear lube it.i got it drained and i am iam ready to put oil back in. please help me out. thanks dave
JB
Re: 85hp
Buy a tube or (bottle with pump) of outboard gearcase (or lower end) lube. It will be 85-90wt.
Pump the grease into the lower (drain/fill) hole with the top (vent) plug out.
When the gearcase is full grease will overflow out the vent hole. Replace the vent plug, with a fresh gasket, before you take the spout out of the fill/drain hole. Then replace the drain/fill plug with a fresh gasket.
moparman
Re: 85hp
Good call JB on replacing the gaskets' as a lot of people skip this part and end up with water in the lower end and spend days trying to find out where it's coming from.
john from md
Re: 85hp
+1 on all of the above. I also suggest using anti seize on the drain, fill and vent plugs. If these seize up in your lower, they are a pain to remove.
John
NYBo
Re: 85hp
Are the gaskets fairly generic, or must they be purchased from a marine supplier?
john from md
Re: 85hp
They are actually plastic washers and you can get them from any Mercury/Quicksilver dealer. Sometimes they can be found at West Marine.
John
