Mark42
Thread starter- Joined
- Oct 8, 2003
- 9,334
Ran the 1985 85hp Force for two weeks on the Peconic bay two weeks ago. It ran well, starts with just a bump of the starter, idles great (smokes a lot at idle - using Mercury or Walmart tcw3 oil) and when the throttle is opened up, it comes on strong.
There are two issues/questions I have:
1) It doesn't like to come off idle and run smooth when the throttle is opened very slowly. It seems to like the carbs to open at least by 1/3 throttle. After reaching cruising speed, the throttle response is good to small changes in throttle. It just doesn't seem to like a slow off-idle accelleration. Carbs were off and are clean as a whistle. Is this just the nature of the beast?
2) When the motor is running at higher speeds, it makes a lot of mechanical noises. A lot more "lose" or "ratty" sounding than my 93 Johnson 40hp twin (only reference I have). Makes me a little nervous to run the motor WOT because it sounds like its ready to munch a bearing or something. Are these things just noisy by design?
