Re: 85hp mercuy thunderbolt stuck in fwd
Sounds like you may have come completely off the follower. Use a small socket the fits the splines on the shift-shaft and turn it until you feel it "click". Now see if you can find neutral and reverse using the same method. You actually have to feel the shift-cam click otherwise if you came off the follower, its going to turn back and forth with nothing happening.
