85hp Mercury
Im Not Very Good When It Comes To Outboards. I've Got An 87' Hydra Sport Bass Boat With An 85hp Merc On It. I Blew The Bottom End On It And Had A Mechanic Rebuild It. Well I Took It On The Water And Noticed It Had Lost Alot Of Power, Im Only Getting To About 35mph, As Before I Could Do 45-50mph...when I Came To A Stop I Looked Back In Curiosity And Seen Water Spitting Out Of The Exhaust, Now I Dont Remeber It Doing That Before. I Know It Comes Out The Pee Hole..... So I Called The Mechanic And He Told Me It Was Normal For It To Come Out Of The Exhaust.... Is This True???
Re: 85hp Mercury
Is This True???
Ayuh,.... That is True...
You should have your Mechanic give it a Tune-up,+ change the Fuel Filters...
Re: 85hp Mercury
Thank You Bond-o:
He Told Me They Tuned It Up When He Changed Out The Bottom End, But I Dont Think They Changed The Fuel Filter, I Will Try That.... Thank You For The Info, It Just Didnt Seem Right For Water To Come Out Of The Exhaust, But Like I Said I Dont Know Much About Marine Motors.
Moody Blue
Re: 85hp Mercury
Is it possible your mechanic just swapper lower units maybe with one of a different gear ratio? Not saying he ripped you off, just maybe he has stock rebuilt units he can swap out.
Are you running the same prop before and after?
Re: 85hp Mercury
Mmmm, I Guess That Could Be Possible...thats One Reason I Do All My Own Work On My Cars, But Not Very Good With Marine Yet, So Still Resorting To Taking Someones Word On Their Work
