85hp Merc Will Only Run On Choke
HDWKING
Ok. Put A New Gas Tank In , New Fuel Line , Primer All The Goods. It Ran Fine Before I Replaced All The Old Equipment. Now I Have To Admit She Sat For 3 Years Before I Got Her Last Month. I Did Start Her About 2 Weeks Ago And She Ran Great Out Of A Gas Can With Mix. I Did Not Clean The Carbs. I Am Thinking Carbs Need To Be Cleaned, Fuel Filter And Fuel Pump Diaphram. Any Thoughts?
JB
Re: 85hp Merc Will Only Run On Choke
Start with the carbs, HDWKING. Your fuel pump is probably okay.
