85hp Force Tilt and trim
NathanFinch
I have a 85hp force motor and the tilt and trim has a problem. It will tilt down but it will no longer tilt up. I was wondering if anyone could help diagnose the problem since I currently do not have the income to take it to a shop. Could this be air in the system? It was working fine then one day it would take a minute to go up but would go down right away.. this continued until finally it would no longer go up.
Any ideas would be appreciated.
Thank you
jerryjerry05
Re: 85hp Force Tilt and trim
You check the fluid?Motor runs? More info please.J
foodfisher
Switch wires. Blue w/ green. If problem reverses the prob. can be explained by Rritt.
RRitt
swap relays and see if problem swaps. relays are cheap. you'll pay more for postage than for the part.
