It sat all winter and I replaced the starter that it needed and it cranks real well now but it doesn't want to fire now,
I put new plugs in and fresh fuel but I need some more advice!!! Thanks
Do a spark test on each cylinder. Make sure you put the correct plugs in the motor. If the motor has a lanyard type safety kill switch make sure it is not in the kill position.
