85hp Force manual tilt bar
IPA006
I'm hoping someone here can help find a replacement tilt/lock bar for my 85hp force. The motor is a manual tilt & trim. My previous bar is somewhere in Charleston harbor.
Thanks in advance
sc gator.
Jack Daniels
Re: 85hp Force manual tilt bar
Ebay has them from time to time. Good luck.
john from md
Try greatlakesskipper.com or american outboards (search for the url)
John
foodfisher
Got one. It came with my 125. RRitt fixed my tilt/trim so it's not needed. Yours for postage. Pm me.
RRitt
you should not tow or store without the bracket. If you hit a pothole then you exceed the rated pressure. Usually the bypass valve opens and the engine drops enough to absorb impact. After enough potholes your prop can drag the ground. However, I have seen cases where the pressure was enough to blow out the seal ... at which point engine drops like a rock.
foodfisher
Yes, I still have it. Send particulars for shipping.
foodfisher
Can't make my PM's go. Only have the tilt/trim bar. The trailering bracket is availiable with a little searching. Do you still want just the bar?
MAXXIE
What happened to "SC Gator" ? I thought that was the guy looking for the part.
