85hp Force - is it toast?
TCSailor
What year is my 85hp Force? The serial number is 1997 and the model number is 856x78. <br /><br />It hadn't been idling well but was running good otherwise. Suddenly, after sittng overnight, only two cylinders were firing and when we pulled the plug on the bad cylinder water ran out of it. What are the possible problems? Cracked block? Worn out cylinder wall? Are these high maintenance engines? Is it time to switch to a Yamaha?<br /> :confused:
chuckz
Re: 85hp Force - is it toast?
85X7B is a 1987 engine.
roscoe
Could just be a blown head gasket.<br />You will have to pull it apart and take a look.<br />Not too expensive, and easy to put in.<br />Pick one up at the local Mercury dealer.
