Boathead 1
Thread starter- Joined
- Oct 30, 2009
- 2
Have an 1989 L-force 85 hp. Have over heating problems. Replaced the impeller and w/p housing. The lower unit is in a tub of water with the hose running (no prop) I started the engine with the thermostat housing off to check water flow-had water. Checked thermostat - opened at 146 Replaced thermostat & housing. Started motor & allowed it to run for 3-4 minutes. Over heat alarm went off. Shut down immediately. Removed L/U- impeller destroyed. This is the second one that has not lasted more than 5-minutes. I installed the impeller to turn clockwise-Am at a loss.....Only 2 impellers left!! HELP???
