Re: 85hp Chrysler Lower Unit Oil Leaking from weep holes? Update Please HELP!
So I did some tests, pushing the piece down onto the drive shaft and pulling it back and every single time the garter spring is off the seal hanging on the drive shaft. I don't know if its the pressing motion of the seal going over the drive shaft that is causing it to come off or the pulling of the seal off the drive shaft that causes it. I'm afraid to move forward until I know for a fact the garter spring is in place properly. Because the drive shaft expands suddenly I'm worried that is whats curling the seal under letting the spring slip off. I just hope I didn't install the seal upside down.
