85 Johnson Won't Stay Running
Jmcjunkin3
Hey guys! So... I've been having an issue with my 1977 85 Johnson where it'll start, run for about 3 seconds, then shut off. Sometimes it'll run long enough for me to get back to the motor and manually throttle it up, and it goes all the way upstairs no problem. I suspected a couple coils due to cracks and intermittent spark, so i replaced them, as well as the fuel pump and I also rebuilt the carbs. Put everything together last night and....same results. Anybody have any ideas? I'm good with cars but not so much small engines, specifically 2 strokes. Any advice would be appreciated! Thanks!
oldboat1
guessing a little about what you are doing ....
When you manually throttle it up back at the engine, are you simply moving the throttle plates, or moving spark advance while opening carbs -- as should happen when using the remote throttle control.
If able to throttle up using the throttle cam/spark advance at the motor, problem is with the remote cable or the box.
Jmcjunkin3
Just the throttle plates. Sometimes if I warm it up by freely revving it, it'll idle fine and I can use the control box to put it in gear and it'll run in the bucket fine. But then the next time it's cold it doesn't wanna stay running again. Today I'm going to be fixing my fuel connection at the fuel pump because the new pump has a smaller fitting on it...then I'll hook it up to a tank of fresh gas and see what happens. when I was doing my tests yesterday my tank was running a little low, so i wanna make sure I eliminate that variable as well...
ondarvr
Are you using the choke/primer to keep it running right after it starts?
Jmcjunkin3
I can't keep it running at all, really...it seems like everytime i go back to the primer it needs primed again. Like the fuel pump isn't working...it's brand new though, and seems to be getting a good pulse from the engine via vacuum. Only other thing i can think of is the tank but it's literally perfect inside and it has run on it before.
Jmcjunkin3
https://drive.google.com/open?id=0B62Fyxg1VzwYNi1FYnVpdERaUzQ
So this is where I'm confused. I got it to idle after lighting it off with some starting fluid. I revved it up back at the carbs, and the thing came back down and idled nearly flawlessly...i put the cover on, revved it at the control (forward and reverse) and it emptied the bucket! Ran great upstairs. Then I refill the bucket, go to start it, and it's back to hiccuping and "sneezing" once again. I have a video but I'm still trying to get it into my google docs...
oldboat1
First impression is that it's some kind of fuel issue -- higher rpm at the end is due to lean running.
Carbs cleaned and rebuilt?
Jmcjunkin3
Well I was actually throttling up at the end, that's why the RPMs rose. Yup, carbs have been taken apart, soaked in carb degunker over night, etc.
Before I stopped messing with it for the night, it was running like a top, as if I had finally cleared something...we'll see what tomorrow brings
Jmcjunkin3
I most definitely will! I prefer a smoking gun when I'm looking for a problem but this time I'll take a miracle...I saw you had a thread about the same kind of issue, did you get it straightened out?
oldboat1
Yeah, I've had similar issues with a number of motors. I think the last motor was a 9.9 trolling motor ('85 Evinrude Yachtwin) -- sat on a boat in a slip. By the end of the year it just wasn't dependable -- symptoms similar to yours.
Compression and spark checked out well. Problem turned out to be a small blockage in the high speed jet, but confess I replaced the fuel pump first, thinking it was past due (believed to be original pump).
Jmcjunkin3
Gotcha...maybe my carbs will have to come apart again. So here's what today brought....
https://drive.google.com/open?id=0B62Fyxg1VzwYNmpheTR3cEVpdkk
This video shows how it runs cold. Won't stay running for more than a few seconds. I got it running long enough to go back and tickle the throttle, where it then started to idle with the start up lever up. As you can see in the next video, it is still sneezing, but it does idle and it does perfectly go upstairs. Once warmed like this it'll idle and run all day. I'm thinking about hitting the water and running it WOT for awhile to see if it clears.
https://drive.google.com/open?id=0B62Fyxg1VzwYbElCRWw2aTZwUWc
oldboat1
can't open the videos yet, but a boat test might tell the tale. Might check the choke valves when back tinkering with the carbs -- make sure valves are closing tight for starting and warm up.
Jmcjunkin3
Yeah sorry, i seem to be having some problems with the uploads. I let the boat sit for an hour, went out, and it started right up! Hasn't done this before. Takes about an hour to get to the river but I'm heading down anyways. Too excited. I'll have all my tools with me too if needed.
thatone123
Banned
I had a similar problem with a 15. Sometimes I am great for "assuming" when I should know better. I assumed this motor did not need simple air/fuel adjustment coz it did not quite have the classic symptoms. WRONG.....it was the air/fuel mixture.
Jmcjunkin3
Well...let's just say things went much worse than expected...sometimes it'll idle all day but won't go upstairs, and sometimes it won't even idle. Most of the time when it's dying it's a very quick shutdown, as if the coils are losing power or something. Whereas if it's running and I try to take it up stairs, it bogs down like it's a fuel issue....I'm stumped, tired, and DONE WITH THIS BOAT!! (Not really, even having it out on the water at all made me realize how much I wanna drive it again)
Jmcjunkin3
How would you adjust this? I know my carbs have fixed jets
oldboat1
Grab compression and spark testers, and check it out. Compression should be even between cylinders, or close to even. Spark should be around a half inch.
