85 Johnson manual lift lever
NH Pete
Needs some help with the lift lever, just bought this boat and it appears the lift lever is bent and I cannot get the engine to lock down.
The lever appears to be riding on the frame and gets jammed when the engine is in the down position. The locking mechanism to keep the engine in the upright position works fine but like I said doesn't engage all the way when down.
Thanks
oldboat1
would need the rod in place for the locking mechanism to work -- rod that is inserted through the brackets to manually set the trim angle. It's called a thrust rod, if looking at a parts diagram.
NH Pete
It's a 1978 85 HP model # 85ML78C
The locking rod is in place but the engine won't lock down on it. The lift lever is bent and seams to prevent it from locking.
Took it out today and it's OK as long as I don't throttle up to fast
F_R
Honorary Supreme Mariner
Well if parts are bent or damaged it would seem that fixing those would be the first step before looking for something more exotic.
emdsapmgr
You can check out the original factory exploded parts diagrams on this website: epc.brp.com. Check out the "exhaust housing" diagram. You should find the parts you need, and can order them from Bombardier.
