85 johnson hesitates on take off
bigbee7848
I have a 1975 johnson 85hp. model 85ESL714.<br /><br />It hesitates upon take off ,It idles and runs top end well. This problem makes water skiing very hard since you need good arms to hold on past the hesitation. <br /><br />I have 3 gas tanks and gas lines and after using them all on another boat I can say they are fine. the engine starts good, and the bulb is hard.<br /><br />The previous owner said that the engine broke down on hime when out on the lake. He was forced to go to some dealer he did not know who fixed the engine, but this problem has been there ever since.<br /><br />I just got the manual and plan on checking what advice might be in there.<br /><br />If anyone could point me in the right direction it would be greatly apreciated.
steve_results
Re: 85 johnson hesitates on take off
I have a similiar problem. I cleaned the tri-carbs out including the high speed jets. Was told that this usually fixes the problem. But did not. I would suggest to 1st clean the high speed jets....then go from there.<br />I will probably put up a psting to see whats next. ;)
skeets
Hello Bee<br />Re-build the carbs Making sure that you get them clean.Soak a few min (15) then use compressed air to insure every passage open.<br />hope this helps.<br /> :)
turtle1173
My manual states that this can also be caused by running your engine too rich. Turn your mixture screws clockwise some (1/4 turn or so) and see if that helps the problem. If it doesn't help, you can always turn them back out.<br /><br />Shane
