85 hp merc. carb.
arnyp
Hi. On my 1976 merc. 85hp there's a knob on the front but it's not hooked up to anything. I took the front plate off and there's nothing there. Does it have a different carb? The choke flap in front is spring loaded shut? There's a choke lever on top but it dosen't affect the spring loaded flap?
hereto
Re: 85 hp merc. carb.
Hi Arnyp,
Don't know what knob you are refering to on the front. The 1976 850 does not utilize a choke "flap", but rather an enrichment valve on each carb. What you are looking at is the throttle plate, it will not move when you pull the choke knob , but you should see the choke rod activate the enrichment valves on the right side of each carb. Post a pic of the knob you are refering to, I'm sure someone will tell you what it is.
hereto
