85 hp johnson 1972-help
Biljud
I have owned my 72 85hp Hydro Electric Shift Johnson (black end plug control box) since about 1978. It has been my baby and always ran great. To me it was the perfect outboard, plenty of power, quiet and smooth running, and great on gas. Now, I have a problem with it and I as well as a few outboard mechanics are stumped. It starts and runs but quits. I could be running full throttle-38-40 mph and BAM it just quits! It almost throws us out of the seats it shuts down so fast. No sputtering, nothing. Completely without warning it just shuts down. Then it won't start at all. I have to wait about 45 minutes and it starts right back up! It is completely unpredictable. Sometimes it will run fine for hours and then other times I can get about 20 minutes out of it. Needless to say we are getting tired of getting towed back to the dock. The motor feels cool to the touch when it breaks down and doesn't appear to be overheating. I had it to the shop several times and have tried and replaced everything 2 or 3 times. Points, coils, dist, wires, plugs, stator, wpump, carbs, fuel filter, etc to no avail. We even replaced the CDI Power Pack 3 times @ 350.00 each! I am actually embarased at how much cash I have sunk into her over this problem. Still the problem exists. I appreciate any insight you guys might have on this. I don't want to get rid of her if I don't have to. Thanks in advance.
toddschubert
Re: 85 hp johnson 1972-help
What about possible debris in fuel system that may intermittently interfere w flow
boobie
How about an intermitten circuit coming from the ignition switch to the pack itself ? Loose or bad wire in the wiring harness? Or maybe bad ignition switch?
emdsapmgr
Weak ignition components tend to fail once the engine reaches normal operating temps. Sounds like this may the what is happening to your engine. In 1972 OMC began to change their ignition systems to a breakerless (no points) type. Unfortunately, your 85 still has the older breaker points system. You can find some excellent troubleshooting at the CDI electronics website: http://www.cdielectronics.com/ Hopefully you can use this information to diagnose your problem. You can view the exploded parts diagrams for your engine on the web at: epc.brp.com
vansullivanjr
The valve on your gas tank could be bad. You know the brass piece that screws into your tank? One time on my boat his happened. We would be going along fine and then it would just cut off.
Faztbullet
Make sure the clipper and monkey nuts are disconnected.....
