85 HP evinrude outboard
jjoker
Starter is popping up when key turned but then it hits fly wheel and makes a wheeeerrrrrr sound its not engaging the wheel how can I fix it or what needs to be done it ran fine and then this happened nothing has been adjusted or changed since it ran? Help!
12Footer
Re: 85 HP evinrude outboard
Nothing needs adjusting. If the gear is ok,and the flywheel is not missing teeth,it's fine.These marine starters do this all the time. Get a can of WD40, and spray it all over the worm gear at the top of the starter. Then,rotate the gear up by hand,and spray the bottom of the worm gear shaft. After it is clean and free, put a drop or two of motor oil or 2cycle oil on the shaft top keep it lubed. You'll have to go thu this routine every season. I don't know why they do that,but they do.<br />Trust me on this one.
