ootransamoo
Thread starter- Joined
- Sep 16, 2013
- 13
Good evening All. I just purchased my first boat and im just knocking out as much little things wrong with it now before i stow it for winter. Its a 1988 85 HP Force, im trying to troubleshoot the steering right now. So far i discontected the steering from the outboard and steering is still stiff even after checking for kinks and greasing up the rod assembly so im going to probably replace the whole assembly and helm unit. with the steering disconected i tryed moving the outboard side to side with that being diifcult too, so i might have to disassemble that pivot point and check it out. i found all zerk fittings not greased up so im guessing im going to have to replace some stuff at that pivot point aswell. where the outboard pivots , what is that called? and am i going a little overboard with replacing it all? just need some tricks of the trade if anyone has come across this before. Thank you in advance.
1988 blue fin sportman with teleflex steering
1988 85 hp force 85 (856y8b)
