85 hp 1975 evinrude v4 impeller
pmosier
I have a manual, but directions are different from reality. I'm trying to drop the lower unit, and I dont want to force anything, but it's loose now, think i'm stuck on the shift linkage. Any ideas?
pmosier
Re: 85 hp 1975 evinrude v4 impeller
release the shift rod.....that's my trouble, on a 1975 evinrude 85 hp
F_R
Are you saying you figured it out? The disconnect is below the carburetors.
pmosier
I see the linkage, just havent quite figured it out, it's not the same as in the manual but at least I'm on the right track.
tashasdaddy
put 2 bolts back in lower to hold lower. you have a bell crank type shift remove the bottom carb, loosen the center bolt the shift rod will release.
you can see diagram here, follow prompts to your motor, to crankcase.
ezeke
You don't have to remove the carburetor, but it would make it easier to reach. You should, however, disconnect and move the the control cables out of the way.
You loosen the fulcrum screw on the bellcrank, then spread the fingers of the bellcrank to release the pin.
Click the thumbnail.
Note the position of the barrel swivel at the top of the shift rod: the flat side faces the driveshaft. Be sure that it is that way when replacing the unit.
pmosier
Thank you, exactly what I'm looking for.
