85 Horse Force-1989
dalaniz1
New to the site and must say what a nice set up.<br /><br />Here goes, top cylinder (#1 ?)stopped firing. Traced problem back to power packs.<br /><br />Since this is a 3 cylinder and the power packs are set up for 4 cylinder I replugged bad lead to the extra to check if coil was bad.<br /><br />Coil fires good. What I need is a diagram on how to re-wire for timing.<br /><br />Any help greatly appreciated.<br /><br />I also wanted to say I bought this 17' center consel back in 89. Other than one coil going bad on me 3 years ago I have never had any problems with this engine.<br /><br />I'm retired Air Force and dragged this boat with me everywhere, It's been in the Atlantic ,Pacific,<br />Gulf of Mexico and a zillion lakes in-between.<br /><br />I must have got lucky, know one can tell me these engines are bad.<br /><br />Regards to one and all.<br /><br />Thanks.
chuckz
Re: 85 Horse Force-1989
The trigger wires for #1 cylinder are the two terminals (#11 & #12) on the far right side of the terminal strip they are either Green or WH./BR./YEL. and Orange or WH./BR./ORG.<br /><br />Move the wire coming from under the fly wheel to the terminals #5 & #6 (Counting left to right).<br /><br />There should be a RED or WHITE/RED wire on #6 and a White/Green wire on the #5.<br /><br />In other words connect the Green or WH./BR./YEL. to the White/Green wire and the Orange or WH./BR./ORG. to the WHITE/RED wire.<br /><br />Then connect the previously unused output from the second power pack to the #1 cylinder coil.<br /><br />A schematic can be found on page 5-70 of the Seloc 1984 - 1999 Force Repair Manual.
dalaniz1
L.I. Chuck;<br /><br />Thanks for the quick reply. I sure appreciate the help.
rosco_59
Redfin22, I am running the same motor as you, I have the diagram of the system you need. Send your e-mail address to me and I will send you the diagram if you need it.<br />bbiers@hereintown.net<br />Bob
