85 force oil/gas ratio????
antman_ga
Hello everyone, im a little confused on how much oil I should add when I fill up on my 85 force 2 stroke. Ive beeb puting 3 ounces to the gallon. That is going by a 50:1 ratio. I know this is kind of a dum question, but this is my first 2 stroke and I want to make sure its right. Its been running fine but I have to clean my plugs off everytime I take the boat out. It runs fine all day, but after the boat sits without running for a while I have no power until I clean the plugs then it runs great. Could this be 2 much oil in the gas. Thanks in advance to anyone who sheds light on this for me.
JB
Re: 85 force oil/gas ratio????
50:1 is the correct ratio, antman.
If you are fouling plugs it may be running too rich on fuel or you may have the wrong plugs.
MWBROWN
50 to 1 is correct. I use 1 pint for 6 gallons which is real close.
I use this ratio with the recommended plugs and I have no problem with my 85 HP Force.
Must be other issues as suggested.
Good Luck,
Mike
