firstboat19
Thread starter- Joined
- Jun 21, 2003
- 21
Hi. I just purchased my first boat - an '85 Bayliner 1600 Capri. It has an 85hp, 2-stroke 3-cylinder Force of the same year. When purchased it started ok for an older engine. I took it out to lake twice and it started fine, but it would not accelerate beyond 1,500 - 2,000 rpm(an estimate, I don't have a tach). The engine sounded good though. So this weekend I decided to check the fuel filter to see whether it was clogged, it turned out to be fine. However now, the boat would not start. I also replaced spark plugs with the same kind several days ago. I've tried to start the boat 20-30 times in the last 2 days and the best I could get is a running engine for 3 seconds. What's up? Before checking up on filter it would start, now it wouldn't...Makes me very sad. Any help greately appreciated.<br />P.S. I bought a new tank, fuel is fresh and is properly mixed w/ oil. Manual rubber pump (right before tank) seems fine. The problem seems to take place after on inside the fuel pump, maybe carbs? One friend advised me to sprinkle some gas into intake to initiate starting, I tried that but it didn't help very much. The engine backfired twice during the whole experience (once I took off the intake cover to sprinkle some gas into carbs, that's when it first backfired). That's all the info I can come up with. Thanks in advance.
