intrigueing
Thread starter- Joined
- Sep 28, 2003
- 11
Ok, the previous owner pulled the shift pin on the motor, I replaced the pin (hoping that everything was still aligned). With the motor in gear (and engine off)the prop spins easily, so I suspect the yoke fell inside the motor. With the motor off and in gear should the spinning the prop require turning over the motor, and not spin freely (if it is actually in gear)? <br />Anyone know what size and type of tool is needed to remove the bolt inside the exhaust in order to drop the lower unit?
