85 9.9 Johnson Broken teeth on linkage
69 Alumacraft
Some of the teeth broke of the gear were the tiller hinges on the motor end. I am not sure how to take it apart. It looks like there is a pin inside but I'm not sure. Looks like the tiller handle has to come off but then I am lost. Any advice would be appreciated.
bktheking
Re: 85 9.9 Johnson Broken teeth on linkage
Which gear is broken , the one on the handle or on the motor?
69 Alumacraft
The ones on the motor.
bktheking
Tiller handle should rotate up out of the way, inside where the gear is there is a circlip that needs to be removed and the gear should slide out.
