85/86 Evnirude 30 hp need a tach?
darrklim2
Re: 85/86 Evnirude 30 hp need a tach?
Mine is electric start and does have an alternator. But it don't have a gray wire.
darrklim2
Well, I got the tach hooked up last night and took the boat out.
My rpm's
Second hole from the bottom - 5900
Third hole from the bottom - 6150
Fourth hole from the bottom - 6100
Does this mean that I should go up to a 10 x15 from my 10 x 13 prop?
Am I correct in that generally there is a 200 rpm drop per pitch?
darrklim2
bump... I realize that it has only been 3 hours since my last post just checking. :)
offshore100
How'd you hook it up w/out a gray wire?
As for rpm's, are these numbers you posted from your new boat? Remember, 4500-5500 @ WOT.
Good luck.
darrklim2
Good luck.
I hooked the pulse wire up to the yellow/gray wire.
These rpm's are from last night with my 1969 lund/shell lake 15 foot fiberglass tri-hull.
As far as I know my rpm's are supposed to be 5200-5800
darrklim2
where'd you hear that? I'm pretty sure the manual says 4500-5500.
From imported_F_R and from every place that I have looked for a prop.
What year are you talking about? My model number is E30TELCOA and is a 1985
darrklim2
offshore - do you have a copy of that manual on pdf or any way I could get a copy from you. Is your motor the same model and year as mine?
darrklim2
If you are right on this I am way over that. Please let me know for sure if that is correct for my motor as well. Thanks
offshore100
Yep, I'm sure. I just rechecked the manual. Sorry, can't pdf file, dunno how, and can't be buggered to learn at the moment.....;)
darrklim2
Well, I have good news. I got my new prop yesterday its a 10 X 15 and my rpms are now 5500. I still don't know my speed because I don't have a speedometer but it is noticable faster. So I am happy with this. Thanks to everyone for all of your help.
