85/120 Evinrude compression 120 and 150psi
Luna Sea
Finally got around to doing the compression test. Both starboard cylinders read 120 and both port cylinders read 150. Anyone know what the compression for a 1985 120 hp Evinrude should be? Runs good enough for the season, I guess. But should I be looking into any ring free additives or anything?
Terry H
Re: 85/120 Evinrude compression 120 and 150psi
120psi sounds about right for that motor...Maybe someone had a warped head on the port side and had it milled...if it runs good I wouldn't be too concerned...just a Thought
ledgefinder
Ensign
I've gotten 130-135 on V4s (115s and a 125 hp) from the late '60s and early 70s, and 120-125 from a 1989 88SPL. The 88 clearly had an added layer of metal to the head to lower compression for the more recent gasoline. Of the few V4s I've tested (5) I haven't seen any higher than 136.<br /><br />That being said, the common belief is that compression variation across all the cylinders should be small - ideally with 5 psi, although I have a Merc manual that says within 20 psi is OK.<br /><br />Could be that you have carbon buildup in two of the cylinders, or that your gauge or measuring technique is different than mine (higher voltage battery, etc.). <br /><br />I'd treat it just the way you are - run some ring-free tuner & not worry about it much for this season. If you're worried/curious, it's not a big deal at all to pull the heads on those V4s and take a look.
