wolfspyryt
- Jul 1, 2008
- 29
Motor was stored without winterizing. Ran well last season. Changed fuel and added SeaFoam (1oz/gallon). Removed and cleaned abit of debris from the bottom of bowls on all 3 carbs. The bottom having the most .. the top the least.
Idles and starts fairly easily and warms up nicely.
Stalls as soon as it goes into forward or reverse.
Idle sounds abit high ... but quite smoothly.
Revs smoothly.
Air Bleed screws are at 1 1/2 turns out. Cant find specs ...
Plugs are burning evenly.
What should the air bleed's be set at?
Thanks in advance for your help
Revs smoothly.
