84 Mercruiser 470
usguppy84
I have a 84 470 and i can not get a spark from the coil to the dist. what am i missing i still have the points system, should i go to electronic? where do i pick one of these up at? i have power to the dist. on the + side of coil! and power to the - side and power to the dist. but it wont spark ! I had it running and then i killed it and again no spark. what do i need to look for? need help . thanks
Re: 84 Mercruiser 470
Ayuh,... Is there Spark at the Points,..??
usguppy84
no sir, no spark no where to be found replaced the points as well after it quit running the first time. once i put new ones on i had a spark then it, well didnt have a spark. it is really strange everything is getting power!
Ayuh,... Check the Grounds then....
usguppy84
ok i never messed with these motors, the grounds to what? i have two wires that are connected together to the+ side of the coil and a gray wire that i cant figure out if it goies to the + side or the - side can you help with that? and i have the wire from the dist. to the - side of coil . thanks sorry im stupid
Bt Doctur
go to the Adults only and download manual #8,
The 2 wires on the pos side should be purple and a purple /yellow
the 2 on the neg side should be black to dist,and gray (tach)
usguppy84
thanks man, sorry i am a dumb a$% thanks for your help i will take a look at all the connections and everything and post it up , and let you knwo if it worked
usguppy84
thanks, i found it right after i posted that, I will try to get to the boat today after work and take a look at the connections. thanks again for your help.
