84 Evinrude in need of help...
Tazman282
I was out today and she was running great for about an hour just cruising up and down the waterway when all of a sudden she started to lose power. Then she jumped right back where she was before. Then about 2 min later she started to fade and the fuel bulb went tight (squeezed together), and she cut off. So I went back and pumped the bulb and then started her up again. Went for about 3 more min and the same thing. This happend over and over for about ten min then nothing for about a half hour when we got in. Not sure what to make of it. Any ideas???
ob
Re: 84 Evinrude in need of help...
Fuel restriction upstream (toward fuel tank) of the bulb.Possible causes: pickup tube in fuel tank obstructed or trash in tank, fuel tank not venting properly, anti-syphon valve on tank fuel fitting defective,primer bulb defective.
D
DJ
Guest
You have a fuel restriction.<br /><br />It is either the tank VENT or the anti siphon valve which is built into tank outlet.<br /><br />Quick check. <br /><br />Does the engine do the same thing with the fuel FILLER cap loose. If so, it is a tank feed problem. The most likely culprit is a valve built into the fuel tank outlet (to engine). You can remove the outlet and remove the check valve, for testing only.
