84 CHRYSLER 90 HP NOT FIRING AT ALL
bassmastere1
NEED HELP: REPLACED TRIGGER ,RECTIFIER, AND STATOR. STILL NO FIRE,ALL THREE TEST OUT FINE.IS IT POSSIBLE FOR BOTH CDI BOXES TO BE BAD AT ONCE.IVE TRIED DISCONNECTING THE KILL WIRES TO THE CDI BOXES AND THE BLUE KILL WIRE TO THE ENGINE TERMINAL STILL NO FIRE. COMPRESSION GREAT OVER 125 DRY TEST.ENGINE IS VERY CLEAN,DOESNT LOOK USED VERY MUCH.ANY SUGGESTIONS ANY USED PARTS ADVIALABLE.OPEN TO ALL SUGGESTIONS IVE SPENT ENOUGH GUESSING.NEED TO FIND OUT EXACT PROBLEM. DEALERS AROUND HERE WONT WORK ON THESE ENGINES.ILL BUY USED PARTS OR A OLD ENGINE IF ANY ONE HAS ONE.MODEL#908V4B SERIAL#1113
eurolarva
Re: 84 CHRYSLER 90 HP NOT FIRING AT ALL
Hello bassmaster and welcome to iboats. Did this motor ever work for you or was this bought in this condition. When you test for spark did you ground the plug tips or use a spark tester? The year chances are is a presto ignition which is not a good thing. Hopefully a force guy can help you with this ignition. If all else fails try the marine doctor. He has a test posted for the presto ignition.
bassmastere1
bassmastere1
IT WAS BOUGHT IN THIS CONDITION,AND YES IT IS THE PRESOLITE TYPE 2 CD BOXES WITH FOUR COILS.I USED A SPARK TESTER.THIS IS A AGGREVATING MOTOR.THANKS FOR THE ADVICE.
J.L.
BM,
It is possible to lose both packs at the same time, but highly unlikely. Sometimes when this motor is intalled on a boat that had an old Chrysler with Battery CD ign., the wiring on the switch is not transferred and you apply 12 volts to the kill circuit burning them both up. Just check for 12 volts at the kill terminal (white wire) with the key on. Should have 0 volts.
You will need a DVA meter to check this ignition and if you don't have one you have no chance.
Packs must absolutely be grounded. Check that ground wire from component mounting plate to the block is in tact and grounded.
Primary voltage comes from Stator and should be at least 150 volts. Bad packs will short primary voltage so check with packs connected and disconnected.
Trigger is polarity sensitive. Hard to hook up backwards though because this system uses the sockets and unless wires have been cut or changed, shouldn't be your problem. Trigger failures usually will only effect one cyl. at a time.
Likewise with coils, usually fail one at a time and are pretty dependable on this ignition.
My guess would be stator. If you only have an ohm meter, check that you have some resistance between the similar colored wires. Yellow to Yellow, Blue to Blue. I'm not sure the value but I believe around 900 ohms. You should have some resistance though, normally a failed stator is either open or shorted to grond, not just slightly out of the parameters. Check for any continuity from Blue to Yellow and to ground. Should be none between them.
CD cannot be tested, only for voltage in and out.
Jerry
bassmastere1
THANKS THIS HELPS ALOT------ JERRY---I WILL DO TESTS THIS WEEK AND LET YOU KNOW
pistolp
i have a 84 chrysler 130 and the distributor was the cause of mine not firing turn the distrubutor and have someone try to start the boat not saying that that is the problem but could be a factor
jerryjerry05
Check the flywheel key too. Make sure your ignition switch is good and no loose wires.Jerry
