84 70hp evinrude fuel problems
snl
What am I missing, I managed to get water in the fuel system,(rookie mistake) I have drained the carb bowls, fuel lines and replaced the tank with fresh gas. Where else do I need to clean. The fuel pump has been rebuilt. The engine will start and run briefly, If I push on the electric choke the engine will run longer. At times there is a backfire as the engine dies.
Is it normal for the butterflys to remain closed with the engine at idle. Ahy help would be greatly appreciated.
Walker
Re: 84 70hp evinrude fuel problems
You probably need to tear down the carbs and give them a thorough cleaning. Water seems to always convey crud into the carbs.
Yes, the throttle plates should be closed at idle.
