hoeser
- Jun 18, 2006
- 253
Hi Guys,
I was hoping you could lend some insight on an issue I've been experiencing pretty much "forever" with my 1984 Evinrude 140 crossflow. I rebuilt the powerhead 2 years ago and installed all new pistons into freshly machined cylinders, the compression is an even 120 on all banks as of a few weeks ago. For as long as I can remember this engine has had this transitional hesitation when putting the hammer down from idle or low speed running to full throttle. The engine runs fine through the entire band but when you quickly advance the throttle it shudders a bit until it "clears its throat" and then you feel the torque come in like a wave of power.
If you are running high rpm and then come back down to idle for a second and reapply full throttle, it usually will not hesitate at all, it will just advance smoothly. If you spend more than a few moments in the low speeds, when you re-advance the throttle to full it will hesitate on the transition.
Hopefully the details here are clear enough to get some ideas. It almost feels like its loading a bit (?)
Thanks in advance!
Thanks in advance!
