'83 V4 140hp Johnson Lower Unit Removal
aggie85
I've removed all the bolts (5) I can find to get the lower unit off and it dropped about 1" but it is still being held by something. Can anyone offer suggestions on what else I need to do and how? Thanks
DHPMARINE
Re: '83 V4 140hp Johnson Lower Unit Removal
Hello,I don't have a manual handy,but you need to disconnect the shift rod under the carbs.<br /><br />DHPMARINE
Hooty
Take the trim tab off, there's another bolt under (above?) it. Then ya gotta deal with the shift linkage.<br /><br />c/6<br />Hooty
DHPMARINE
I'm Back...<br />Grabbed the manual today.To disconnect the shift,slotted screw,under carbs,starboard side,just ahead of the block.Probably is also 3/8 or 7/16 hex.<br />good luck,DHPMARINE
