Re: 83 Merc 40hp
As long as you haven't turned it over, it should be ok...In most cases. It all depends on how much old fuel was in the circuit when it was stored.<br />One other thing I would do before hitting the water with her, is chenge out the impeller. After 4 years of sitting in one spot, it no doubt, has shaped itself in the housing. It will look find,except for the fact that the vanes will be bent over. It will work for a short time,then quit.
