83 Johnson 50
Status
Not open for further replies.
Destiny21172
I wonder if someone could tell me if the bolt for the "filler block" (looks like a sacrificial anode but parts diagram says different) is threaded only into the lower unit or goes through and is threaded into the exhaust housing just as the other LU bolts are. LU is stuck, that's the reason for the question. Everything else is free but the tail end of the LU doesn't wanna break loose.
Destiny21172
Lower unit is off. Sorry to inform boobie that the filler block bolt is actually not threaded into the exhaust housing, only the LU itself. Perhaps you thought I was referring to the trim tab.
Honorary Supreme Mariner
Perhaps you are referring to the sacrificial anode !----Sorry if you are new at outboard part nomenclature.----Do not ridicule those with up to 50 years experience !
Destiny21172
It's not a sacrificial anode, it's a damn piece of plastic. Look at the parts diagram ya arrogant ass. I have several years myself...I know the difference!
Destiny21172
Pardon my hasty reply racerone. I have read this forum for quite some time before joining. I have seen your attitude. I know you're better than me but I'm looking at a simple piece of PLASTIC as I write this. Plastic is NOT sacrificial and on this particular motor the parts diagram states it is not a sacrificial anode. Look it up.
Destiny21172
Oh damn...the great racerone got corrected. NO Fing way. Quit being a **** to those who are not chosen as you are. You just have a better than anyone attitude and maybe should consider not giving advice altogether. Just because you and others have 50 years exp does not automatically make you right. I respect everyone's exp but I am holding a piece of plastic in my hand. It is called a filler block. There IS NO SACRIFICIAL ANODE ON THIS MOTOR. Again, look it up. And quit being a ****!
Destiny21172
PERHAPS the administrators of this site should consider banning racerone due to his "you're a piece of ****" attitude to those who don't believe he's God
Destiny21172
And on the lighter side, I was not ridiculing anyone. In my first post I said...oh hell just read it
Destiny21172
Boobie, absolutely no offense to you. We may have not been thinking about the same part.
oldboat1
http://ww2.iboats.com/Gearcase/dm/cart_id.659416679--session_id.029229145--view_id.1539900
Interesting — anode kit available for some models (like yours), with anode standard on others. That configuration with a bolt hidden under the trim tab has been around for years (since ’70 for sure, maybe longer), but not sure when the anode/ filler block made an appearance. I remember my ’70 85 could have used an anode, as one of the bolts under there sheared when I tried to remove it (salt water use).
GA_Boater
Someone put on their big girl panties! And I don't mean boobie.
We don't call other members names. We are grownups and watch our language. Watch your words!
Closed for cause!
Status
