tallcar
- Jul 20, 2002
- 143
1983 Johnson 35 hp runs fine but will not shut off when key turned off? I have replaced the key switch, that still does allow it to shut down. I have checked for continuity from the key switch back to power pack on the black/yellow stripe wire, it checks fine ans so does the black wire from the key switch to the ground at the coil.
I normally deal with much older motors, from the 1914 Evinrude to my 1955 Evinrude. So much easier to deal with as none of this routing one function thru 15 parts all intertwined so you spend days on a simple project.
On to other trouble shooting. Diagnostics say for me to "Disconnect the stop wire from the power pack, connect a jumper to stop wire to ground. If it, ( the power pack ) stops sparking the stop circuit is at fault. Check the key switch, harness and shift switch, If this does not stop the pack from sparking replace the power pack."
That is taken from an online source here:
http://issuu.com/cdielectronics/doc...231¬eText=¬eX=¬eY=&viewMode=magazine
Now I have the wiring diagram for this motor, but for the life of me I can't seem to gather which wire is the stop wire?
Any thoughts?
Thanks
Richard
Any thoughts?
Thanks
Richard
