kill switch is good. I checked continuity on both leads, and copper contacts on switch look great. so where to from here? what is downstream of the kill switch and how do I check it? thanks
One lead goes to the 3 pin connector to the power pack, the other lead is grounded on the engine block.
So I would check for continuity between one wire and the engine block. Then check the other wire and 3 pin connector.
