83 johnson 115 no spark
Ralphc
Boat lost all spark and after reading another post we diconnect rd the red harnes plug and the motor fired right up and continues to die when the red plug is plugged in. My question is what could be the issue ? Any help would be appreciated thanks
Bosunsmate
sounds like a short on the kill circuit.
try discoonecting the black wire with yellow stripe on the powerpacks and work back from there.
Often its the key switch n the control going sick
Ralphc
Thanks we tried disconecting the black/yellow wires but no luck. Still only starts with the red lug disconnected.
jakedaawg
Check kill switch and key switch with ohmmeter. Test detailed in manual or you could search for them on here.
James R
The most common failure is forgetting to fit the dead man cord to the klll switch. I know, after all these years I still sometimes forget.
Ralphc
Thanks for all the replays much appreciated. I pulled most the harness out and found a bubble cut it open and found the black/yellow and gray wires shorted. Repaired it and runs fine. No idea what caused it but most of the electrical is replaced now so hopefully it's good. Thanks for all the help. Btw I've never touch a boat motor before this weekend. It's my father in laws boat. Thanks again
