Supposed to be (ideas on removing 1983 115hp impeller from shaft)I got to my impeller, after pulling off the housing and inspecting it, there looks to be a piece that has broke off or even melted away. I am going to try and add a picture. Also found that the blades on the impeller are cracked and damaged. I am unable to get the impeller off the shaft though. I have tried carefully to pry it off so as not to scratch the shaft but have had no luck. It is really on there. Any ideas I could try? As for the pictures i am not having any luck.
