83 Evinrude 60 - Strange starting
ruffneck2
I have a 83 Evinrude 60 that I just cannot get to work here is what I am done
-Cleaned carbs (jets, drains, floats work) they are all clean
-Changed fuel filter (new gaskets)
-Changed fouled plugs (thought it kept fouling them but I am not sure anymore)
-Checked compression all good minor difference between cylinders but still strong
Here is what happens and I just cannot figure it out
Fuel primed into empty carbs, fresh fuel, start motor chocked fast start on. The motor will start for about 5 seconds, rough idle then it will quit, start it again and sometimes you can rev it up but it will just QUIT like hard quit just stop and backfire, sometimes it will have a decent idle then give it gas and it starts to rev then quits. It pointed to fouled plugs but after multiple times cleaning them and or new ones I am at a loss. It almost seems like the timing is off, could it be the CDI box?
Any help would be great! This motor has never treated me bad and I have taken awesome care of it, it just started doing this year. I cant imagine it being a piston ring since it does idle?
Thanks in advance!
( I can post a short video of what its doing if that helps anyone, I have had my mechanic friend who builds hotrods for a living and he is stumped too)
Monte1961
Re: 83 Evinrude 60 - Strange starting
try squeezing the primer bulb to see if it will stay running. also pull fuel line of between fuel pump and carb/s, turn engine over to see if it pulses fuel. post back results!
ruffneck2
It should pulse while the boat is trying to start correct?
Daviet
Correct, the pump operates off of a pulse created by a piston moving back and forth. What plugs are you running?
ruffneck2
The pump is pulsing fuel, NGK B7HS10. It revs up with starting fluid just fine
Will Bark
You MAY want to change to Champion plugs You MUST quit using starting fluid which has no lubricant and will ruin your engine; use a squirt bottle of premix fuel instead.
ruffneck2
The starting fluid was only for a very short time to see if it was a fuel/spark problem now be it it ran on starting fluid pretty well, I am just back to square one here
-Fuel pump pluses fluid
-spark plugs new (work on SF) will be changing to the OG Champion plugs
-carbs have fuel in them opened drain to see
it still will start for a very short time, very rough then backfire and quit, but it wont do this on starting fluid! I am desperate here, its hot out!
Thanks!
Monte1961
use a spray bottle and fog the carb/s. will it stay running? 50:1 fuel mix.
Daviet
Just because there is fuel in the carbs it does not mean that the fuel is reaching the engine.
When you overhauled the carbs did you remove the core plug on top of the carbs and clean the tiny passages in there? Did you remove both the idle orifices and make sure they were clean?
As Monte1961 suggested, squirt some fuel mixture into the carbs and see if it will run, if so, you have carb problems.
