83 evinrude 50 impeller with plastic key
Limige01
Hey guys, my dad bought this motor for his boat. It's an 83 evinrude 50 hp model e50belcta
I believe the lower unit has been swapped.
I'm trying to find the correct impeller. I come up with part number 777129, I bought one off eBay and it has the wrong style key
I need the plastic wedge shaped key for mine. I'm not having much luck finding the correct number
it uses pump housing number 384087 seal 460359
oldboat1
looks like 0323950 (key) for impeller 0389589 / 0777129. The Sierra version of the impeller is 18-3055.
Limige01
I was told 396809 will be the one. Finally got ahold of the eBay seller I purchased the wrong one from. He said it's a newer lower unit
lmbr
i just went thru this with an 84 60 hp. Ordered several impellers and keys all the wrong size. I finally got the correct key. It is white in color and the smaller size. (Wish I still had the part #) But there are 2 of the wedge style keys, the white (smaller one) and a black one which is larger. I believe there are only these two so if the one you have is black you need the white one or visa versa.
Rustywrench
#344470 is white. Larger wedge, but thinner. #334897 is black. It is smaller, but thicker. If your not confused now, you will be. OMC did a bad job of explaining this. Worked fine while they were sending both wedges with the impellers!
Limige01
So, what are the chances the newer lower unit could be a different gear ratio?
can only get the boat to do 13 mph. Runs well, checked the timing and that's not it. New prop, I ran through a prop calculator and got what it suggested, struggling to figure out why it isn't reaching full rpm. No tach but it's struggling.
