ulsterman50
Thread starter- Joined
- Mar 17, 2018
- 3
bought this engine last fall, owner said it was cold blooded so over winter I rebuilt fuel pump, water pump, carb and put in a new ignition brain. Started it today and it runs fine at full and 1/2 throttle but won't idle. When running, the Choke needs to be 1/2 open, open full and it stalls. I like fooling around with engines so really don't want to take it to service pro. I set the float drop with a ruler, but didn't have the special float tool. Have I got a float issue? I did order the special tool and plan on taking the carb back off and using the float tool. Adjusting the slow idle needle doesn't seem to help, it just wont run a slow speed and does jump around quite a bit. Seems to me its too lean, but only adjustment I have is the low speed needle.
