'83 70HP Mercury fuel mix ratio
htmccarren
Re: '83 70HP Mercury fuel mix ratio
Greg thanks for the quick reply please bare with me since I am a rookie, so if I put 10 gallons of gas in the tank how much oil, and what kind of oil should I get? Is my motor a 2 stroke?
htmccarren
can someone please answer my question below, I'd really appreciate before it gets lost in the mix....
Thanks
Fred P
You can mix 28 oz. of tcw lll 2 stroke oil with 10 gal. fuel and fill comfortable.
Irv964
Make sure you shake the gas can well after adding the oil. I always filled my 5gal gas can first and then added the oil, some added the oil first and then the gas but I found it stayed on the bottom too much.........Irv
htmccarren
Thanks you guys for all your help I really do appreciate it.
So TCW III oil for the mix?
Am I looking for a specific brand, I don't know exactly what TCW III oil is...
Sorry I am such a rookie, I just don't want to make any mistakes!
Can I get this at Fleet Farm?
And while I am at Fleet Farm should I get a 5 gallon gas container?
Then at the gas station should I fill the 5 gallon container with gas, add the 28 oz. of oil shake it up a little and then add 5 more gallons from the gas pump into the boat? Because I have a place to just put the nozzle of gas pump right into the boat?
Thanks again I really appreciate it!
Have a great weekend on the water
