Hi all<br /> Im new to these forums but hopefully I can provide enough info to get an answer on my problem.<br /><br /> I run my my boat for 2-3 minutes it will turn about 4000 rpms tops (which I dont think is right either) then it will start to bog and rev a little and bog and rev. Then I will try to go full throttle again it wont let me will bog again. The olny way to move is slow 3000 rpms max or it will bog?? Im stumped I've changed lots of parts this year.<br /> 1 new carbs gaskets and fuel pump diaframs<br /> 2 all new fuel lines inside the engine area<br /> 3 new plugs<br /> 4 new CDI box last year<br /><br /> When I take the plugs out after running it they are fouled im pretty sure.<br /> I have adjusted the low speed screws on the carbs as per my manual. Set to idle at 900 rpms. I have 2 carbs are they supposed to be adjusted differently? One richer or leaner? If I try to lean it out at all it wont idle. I am stumped any help in this matter would be greatly accepted.<br /><br /> THX. Marshman
